Configures L2 protocol port blocking type.
| ingress-filtering | Specifies blocking based on hardware VLAN membership (default). |
| spanning-tree-group | Specifies blocking based on hardware spanning tree group state. |
ingress-filtering
Consider using the spanning-tree-group option with OnePolicy or Instant Port Profile if STP is enabled.
The following command configures the L2-Protocol blocking-type spanning-tree-group:
configure forwarding L2-protocol blocking-type spanning-tree-group
This command was first available in version 32.5.
